跳转到主内容
加入维修社区 - 创建账户
Ematic FunTab 3 Motherboard Replacement
你所需要的
  1. Ematic FunTab 3 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 Ematic FunTab 3 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 Ematic FunTab 3 Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    询问修复机器人
    添加评论
  2. Ematic FunTab 3 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pull the back panel away from the screen.
    询问修复机器人
    添加评论
  3. Ematic FunTab 3 Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the black tape to reveal the wire ribbon connector.
    询问修复机器人
    添加评论
  4. Ematic FunTab 3 Motherboard Replacement: 步骤 4 中的图像 1,3 Ematic FunTab 3 Motherboard Replacement: 步骤 4 中的图像 2,3 Ematic FunTab 3 Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
    询问修复机器人
    添加评论
  5. Ematic FunTab 3 Motherboard Replacement: 步骤 5 中的图像 1,3 Ematic FunTab 3 Motherboard Replacement: 步骤 5 中的图像 2,3 Ematic FunTab 3 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
    询问修复机器人
    添加评论
  6. Ematic FunTab 3 Motherboard Replacement: 步骤 6 中的图像 1,2 Ematic FunTab 3 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    询问修复机器人
    添加评论
  7. Ematic FunTab 3 Motherboard Replacement, Speaker: 步骤 7 中的图像 1,2 Ematic FunTab 3 Motherboard Replacement, Speaker: 步骤 7 中的图像 2,2
    询问修复机器人
    添加评论
  8. Ematic FunTab 3 Motherboard Replacement: 步骤 8 中的图像 1,3 Ematic FunTab 3 Motherboard Replacement: 步骤 8 中的图像 2,3 Ematic FunTab 3 Motherboard Replacement: 步骤 8 中的图像 3,3
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
    询问修复机器人
    添加评论
  9. Ematic FunTab 3 Motherboard Replacement, Camera: 步骤 9 中的图像 1,2 Ematic FunTab 3 Motherboard Replacement, Camera: 步骤 9 中的图像 2,2
    询问修复机器人
    添加评论
  10. Ematic FunTab 3 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use the plastic opening tool to flip up the black retaining tab.
    询问修复机器人
    添加评论
  11. Ematic FunTab 3 Motherboard Replacement: 步骤 11 中的图像 1,2 Ematic FunTab 3 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    询问修复机器人
    添加评论
  12. Ematic FunTab 3 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove the black tape to reveal the screen connector.
    询问修复机器人
    添加评论
  13. Ematic FunTab 3 Motherboard Replacement: 步骤 13 中的图像 1,2 Ematic FunTab 3 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    询问修复机器人
    添加评论
  14. Ematic FunTab 3 Motherboard Replacement: 步骤 14 中的图像 1,2 Ematic FunTab 3 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    询问修复机器人
    添加评论
  15. Ematic FunTab 3 Motherboard Replacement: 步骤 15 中的图像 1,1
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Amanda Davis
于07/11/18注册
581 声望
创作了5篇指南
团队
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 35
总计 619
