跳转到主内容
Electric Eel Drain Cleaner Cable Replacement
你所需要的
  1. Electric Eel Drain Cleaner Cable Replacement, Remove the Guide Spring: 步骤 1 中的图像 1,3 Electric Eel Drain Cleaner Cable Replacement, Remove the Guide Spring: 步骤 1 中的图像 2,3 Electric Eel Drain Cleaner Cable Replacement, Remove the Guide Spring: 步骤 1 中的图像 3,3
    • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
    • Wear gloves to protect your hands from injury when handling the cable.
    • Ensure the cable is completely retracted into the auto-feeder.
    • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
    • Remove the guide spring.
  2. Electric Eel Drain Cleaner Cable Replacement, Release the Tension Spring: 步骤 2 中的图像 1,3 Electric Eel Drain Cleaner Cable Replacement, Release the Tension Spring: 步骤 2 中的图像 2,3 Electric Eel Drain Cleaner Cable Replacement, Release the Tension Spring: 步骤 2 中的图像 3,3
    • Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
  3. Electric Eel Drain Cleaner Cable Replacement, Set the Feeder in Neutral Position: 步骤 3 中的图像 1,3 Electric Eel Drain Cleaner Cable Replacement, Set the Feeder in Neutral Position: 步骤 3 中的图像 2,3 Electric Eel Drain Cleaner Cable Replacement, Set the Feeder in Neutral Position: 步骤 3 中的图像 3,3
    • Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
  4. Electric Eel Drain Cleaner Cable Replacement, Disengage the Top Bearing: 步骤 4 中的图像 1,2 Electric Eel Drain Cleaner Cable Replacement, Disengage the Top Bearing: 步骤 4 中的图像 2,2
    • Push the top control finger up as far as possible.
    • This disengages the top feeder assembly and allows the cable to freely move through the feeder. The finger may fall back down on its own and restrict cable movement. If this occurs, simply push the finger back up.
  5. Electric Eel Drain Cleaner Cable Replacement, Uncoil the Cable: 步骤 5 中的图像 1,2 Electric Eel Drain Cleaner Cable Replacement, Uncoil the Cable: 步骤 5 中的图像 2,2
    • Grab the end of the cable and pull to begin removing the cable from the drum.
    • If the the cable won't pass through the feeder, ensure that the top bearing is completely disengaged as described in step 4 of this guide.
  6. Electric Eel Drain Cleaner Cable Replacement: 步骤 6 中的图像 1,2 Electric Eel Drain Cleaner Cable Replacement: 步骤 6 中的图像 2,2
    • Continue pulling out the cable until it reaches the end. The very end of the cable and the cable anchor will still be attached to the back side of the drum.
  7. Electric Eel Drain Cleaner Cable Replacement, Remove the Cable Anchor: 步骤 7 中的图像 1,1
    • Use a flat-head screwdriver to remove the screw on the rear face of the drum that secures the cable anchor.
    • You may need to rotate the drum so that the screw is accessible from bottom rear of the drain cleaner.
    • During reassembly, twist the cable so that the threaded hole in the cable anchor is facing the back side of the drum.
  8. Electric Eel Drain Cleaner Cable Replacement: 步骤 8 中的图像 1,3 Electric Eel Drain Cleaner Cable Replacement: 步骤 8 中的图像 2,3 Electric Eel Drain Cleaner Cable Replacement: 步骤 8 中的图像 3,3
    • Pull the end of the cable out of the side of the drum to access the cable anchor.
  9. Electric Eel Drain Cleaner Cable Replacement: 步骤 9 中的图像 1,1
    • Use a 1/8" hex key to remove the grub screw from the cable anchor.
  10. Electric Eel Drain Cleaner Cable Replacement: 步骤 10 中的图像 1,2 Electric Eel Drain Cleaner Cable Replacement: 步骤 10 中的图像 2,2
    • Remove the cable anchor from the cable.
  11. Electric Eel Drain Cleaner Cable Replacement, Remove the Cable: 步骤 11 中的图像 1,3 Electric Eel Drain Cleaner Cable Replacement, Remove the Cable: 步骤 11 中的图像 2,3 Electric Eel Drain Cleaner Cable Replacement, Remove the Cable: 步骤 11 中的图像 3,3
    • Pull the rest of the cable out of the drum through the auto-feeder to remove it.
结论
3等其他人完成本指南。
Tarun Thiruma
于11/20/19注册
36,244 声望
创作了134篇指南
2条评论
make sure to feed back in counter clockwise
MIGUEL - 回复
there is a ANCHOR CABLE, P/N: 1/2M3, that can be left on the drum and the new cable can be attached to it. Much easier to change the cable when yo don't have to re-attach it each time, to the drum.
MICHEL - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 77
总计 5,066
