跳转到主内容
Echo Chain Saw CS590 2019 Oil System Replacement
你所需要的
  1. Echo Chain Saw CS590 2019 Oil System Replacement, Turn off the chainsaw: 步骤 1 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Turn off the chainsaw: 步骤 1 中的图像 2,2
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Oil System Replacement, Loosen the air filter cover: 步骤 2 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Loosen the air filter cover: 步骤 2 中的图像 2,2
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 3 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 3 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 3 中的图像 3,3
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the spark plug: 步骤 4 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the spark plug: 步骤 4 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the spark plug: 步骤 4 中的图像 3,3
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the air filter: 步骤 5 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the air filter: 步骤 5 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the air filter: 步骤 5 中的图像 3,3
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front handle: 步骤 6 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front handle: 步骤 6 中的图像 2,2
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front handle: 步骤 7 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front handle: 步骤 7 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front handle: 步骤 7 中的图像 3,3
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the sprocket guard: 步骤 8 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the sprocket guard: 步骤 8 中的图像 2,2
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 9 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 9 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 9 中的图像 3,3
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the guide bar: 步骤 10 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the guide bar: 步骤 10 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the guide bar: 步骤 10 中的图像 3,3
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front hand guard: 步骤 11 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the front hand guard: 步骤 11 中的图像 2,2
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front hand guard: 步骤 12 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the front hand guard: 步骤 12 中的图像 2,2
    • Pull the front hand guard toward the rear of the device to remove it.
  13. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the engine cover: 步骤 13 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the engine cover: 步骤 13 中的图像 2,2
    • Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
  14. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the engine cover: 步骤 14 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the engine cover: 步骤 14 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the engine cover: 步骤 14 中的图像 3,3
    • Pull the engine cover straight off the device to remove it.
  15. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil cap: 步骤 15 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil cap: 步骤 15 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil cap: 步骤 15 中的图像 3,3
    • Use your fingers to loosen and remove the oil cap.
  16. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil filter: 步骤 16 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil filter: 步骤 16 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil filter: 步骤 16 中的图像 3,3
    • Use a flathead screwdriver, or your fingers, to remove the oil filter from its recess in the fuel assembly.
  17. Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 17 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 17 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 17 中的图像 3,3
    • Pull on the oil filter to separate it from the fuel pipe.
  18. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the inner guide plate: 步骤 18 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the inner guide plate: 步骤 18 中的图像 2,2
    • Insert the edge of a screwdriver between the inner guide plate and the chassis.
    • Pry up with the screwdriver to initially separate the plate.
    • Slide the plate out of its two bolts to remove it.
  19. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the brake cover: 步骤 19 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the brake cover: 步骤 19 中的图像 2,2
    • Use a T25 Torx screwdriver to remove the four screws securing the brake cover:
    • Three 20 mm-long screws
    • One 16 mm-long screw
  20. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the brake cover: 步骤 20 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the brake cover: 步骤 20 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the brake cover: 步骤 20 中的图像 3,3
    • Pull the brake cover straight off the clutch drum to remove it.
  21. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the E-ring: 步骤 21 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the E-ring: 步骤 21 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the E-ring: 步骤 21 中的图像 3,3
    • Use E-ring pliers, or a flathead screwdriver, to remove the E-ring on the clutch drum.
  22. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: 步骤 22 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: 步骤 22 中的图像 2,2
    • Use your fingers to pull the washer straight out of its housing to remove it.
  23. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch drum: 步骤 23 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch drum: 步骤 23 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch drum: 步骤 23 中的图像 3,3
    • Pull the clutch drum straight out of its recess to remove it.
    • The needle bearing should come out with the clutch drum. Make sure bearing is reinserted before reinstalling the clutch drum.
  24. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the spark plug: 步骤 24 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the spark plug: 步骤 24 中的图像 2,2
    • Use a spark plug socket to loosen and remove the spark plug.
  25. Echo Chain Saw CS590 2019 Oil System Replacement, Insert a rope: 步骤 25 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Insert a rope: 步骤 25 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Insert a rope: 步骤 25 中的图像 3,3
    • Feed a piston stopping cord or rope through the cylinder head into the combustion chamber until the crankshaft can no longer rotate.
    • Do not insert the entire cord into the combustion chamber.
  26. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch assembly: 步骤 26 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch assembly: 步骤 26 中的图像 2,2
    • Use a clutch removal tool and a wrench to loosen the clutch assembly.
    • Rotate the wrench clockwise instead of counter-clockwise.
  27. Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 27 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 27 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 27 中的图像 3,3
    • Use your fingers to loosen the clutch assembly and remove it from the crankshaft.
  28. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch plate: 步骤 28 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch plate: 步骤 28 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the clutch plate: 步骤 28 中的图像 3,3
    • Use your fingers to pull the clutch plate straight off of the crankshaft and remove it.
  29. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the collar: 步骤 29 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the collar: 步骤 29 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the collar: 步骤 29 中的图像 3,3
    • Use pliers, or your fingers, to pull the collar off of the crankshaft and remove it.
  30. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the worm gear: 步骤 30 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the worm gear: 步骤 30 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the worm gear: 步骤 30 中的图像 3,3
    • Use pliers to pull the worm gear straight out its housing to remove it.
  31. Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the oiler assembly: 步骤 31 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the oiler assembly: 步骤 31 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Disconnect the oiler assembly: 步骤 31 中的图像 3,3
    • Use your fingers, or a flathead screwdriver, to disconnect the top oil pipe from the oiler assembly.
    • Only use a flathead screwdriver if the fuel pipe is too tight. The sharp edge could cause a split in the pipe.
  32. Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 32 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement: 步骤 32 中的图像 2,2
    • Use your fingers, or a flathead screwdriver, to disconnect the right oil pipe from the oiler assembly.
  33. Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the oiler assembly: 步骤 33 中的图像 1,2 Echo Chain Saw CS590 2019 Oil System Replacement, Unfasten the oiler assembly: 步骤 33 中的图像 2,2
    • Use a T25 Torx screwdriver to remove the two 15 mm screws securing the oiler assembly.
  34. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oiler assembly: 步骤 34 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oiler assembly: 步骤 34 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oiler assembly: 步骤 34 中的图像 3,3
    • Use pliers, or your fingers, to pull the oiler assembly straight out its housing to remove it.
  35. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: 步骤 35 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: 步骤 35 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the washer: 步骤 35 中的图像 3,3
    • Use pliers, or your fingers, to pull the washer off of the crankshaft and remove it.
  36. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil outlet port: 步骤 36 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil outlet port: 步骤 36 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil outlet port: 步骤 36 中的图像 3,3
    • Use a flathead screwdriver to pry the oil outlet port out its recess in the chassis.
    • Remove the oil outlet port.
  37. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil pipe: 步骤 37 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil pipe: 步骤 37 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the oil pipe: 步骤 37 中的图像 3,3
    • Thread the oil pipe through the oil cap recess to remove it.
  38. Echo Chain Saw CS590 2019 Oil System Replacement, Remove the grommet: 步骤 38 中的图像 1,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the grommet: 步骤 38 中的图像 2,3 Echo Chain Saw CS590 2019 Oil System Replacement, Remove the grommet: 步骤 38 中的图像 3,3
    • Use a pick tool to remove the grommet next to the clutch assembly's recess.
结论
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
125,022 声望
创作了582篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
3条评论
***Step 36*** Remove the retaining ring . Is there a reason to remove, unless you're doing a complete teardown?
VAL - 回复
Hi there.
You're right! That was a left over from a different procedure, and I'll remove the step. Thank you!
Alex Diaz-Kokaisl -
Is there a torque value for the clutch? If so, what is it?
SHANE - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 40
过去 30 天: 214
总计 2,066
