跳转到主内容
EVGA x17 Optical Sensor Board Replacement
你所需要的
  1. EVGA x17 Optical Sensor Board Replacement, Optical Sensor Board: 步骤 1 中的图像 1,1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Optical Sensor Board Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Optical Sensor Board Replacement: 步骤 3 中的图像 1,1
    • Remove the weight chamber cover.
  4. EVGA x17 Optical Sensor Board Replacement: 步骤 4 中的图像 1,1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
    • You can also use an iFixit opening tool to pry open the bottom panel.
  5. EVGA x17 Optical Sensor Board Replacement: 步骤 5 中的图像 1,2 EVGA x17 Optical Sensor Board Replacement: 步骤 5 中的图像 2,2
    • Remove the 2 screws to gain access to the sensor board.
  6. EVGA x17 Optical Sensor Board Replacement: 步骤 6 中的图像 1,1
    • Pop the optical sensor out and replace it.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 254
