跳转到主内容
Dyson V8 Animal Brush Bar Replacement
你所需要的
  1. Dyson V8 Animal Brush Bar  Replacement, Brush Bar: 步骤 1 中的图像 1,1
    • Push the red button and then slide the brush head off of the shaft.
    • The shaft must be held from moving when sliding the brush head off.
  2. Dyson V8 Animal Brush Bar  Replacement: 步骤 2 中的图像 1,3 Dyson V8 Animal Brush Bar  Replacement: 步骤 2 中的图像 2,3 Dyson V8 Animal Brush Bar  Replacement: 步骤 2 中的图像 3,3
    • Insert a coin into the slot on the side of the brush head.
    • Turn the coin counter clock wise to unlock the brushbar.
    • Pull the brushbar straight out of the brush head.
    • Clean all debris off of the brushbar and from inside the brush head.
    • The brushbar will spring outwards slightly when unlocked successfully.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S19-G1, White Winter 2020 Cal Poly, Team S19-G1, White Winter 2020 的会员
CPSU-WHITE-W20S19G1
4 名成员
创作了10篇指南
4条评论
Did that but brush still will not spin.
walt.florence - 回复
I can't remove the brush, it springs outwards but keep firmly attached to the "axis". I've also tried to remove the transparent cover, by removing all the screws I've found on it (6 in total) but seems impossible. Can anyone please post a step by step guide about how to dissemble the whole brush bar??
Henar Lanchas López - 回复
I’m saving my Pennys for the “coin tool”. It does seem hauntingly familiar however….
Enrico Crocetti - 回复
I am unable to insert a coin into the slot provided. No problem previously
Mgt trotter - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 141
总计 5,007
