跳转到主内容
Dyson Pure Cool AM11 Oscillation Motor Replacement
你所需要的
  1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: 步骤 1 中的图像 1,3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: 步骤 1 中的图像 2,3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: 步骤 1 中的图像 3,3
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 2 中的图像 1,3 Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 2 中的图像 2,3 Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 2 中的图像 3,3
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 3 中的图像 1,2 Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 3 中的图像 2,2
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 4 中的图像 1,3 Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 4 中的图像 2,3 Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 4 中的图像 3,3
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
  5. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: 步骤 5 中的图像 1,2 Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: 步骤 5 中的图像 2,2
    • Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
  6. Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 6 中的图像 1,2 Dyson Pure Cool AM11 Oscillation Motor Replacement: 步骤 6 中的图像 2,2
    • (Optionally) Use a jimmy around the edge of the motor to loosen it from its housing.
    • Lift the motor out of its housing.
    • Ensure that you do not grab the motor by the swing arm as you may damage both the motor and surrounding components.
终点
另外一个人完成了本指南。
AidenManchester
于11/01/23注册
252 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 的会员
UMASSD-GULBRANDSEN-F23S2G7
3 名成员
创作了5篇指南
2条评论
Where’d you get the motor
Jon Murch - 回复
any luck finding the proper motor replacement?
Kay -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 44
总计 740
