跳转到主内容
Dyson Cyclone V10 Absolute Motor Assembly Replacement
你所需要的
  1. Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: 步骤 1 中的图像 1,3 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: 步骤 1 中的图像 2,3 Dyson Cyclone V10 Absolute Motor Assembly Replacement, Motor Assembly: 步骤 1 中的图像 3,3
    • Remove the extra parts of the vacuum, including the filter and the bin.
    • Press the red arrow under the bin and pull it out.
    • Remove the filter by turning it counterclockwise.
    • Prior to starting the repair, remove the battery.
  2. Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 2 中的图像 1,3 Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 2 中的图像 2,3 Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the one 16.5 mm screw on the back of the handle and two 16.5 mm screws under the battery.
    • Pull the battery downward to remove.
    • If you're just replacing the battery, follow the first two steps in reverse order.
  3. Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 3 中的图像 1,2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four 16.5 mm screws on the back of the vacuum.
  4. Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 4 中的图像 1,2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 16.5 mm screws under the middle of the vacuum, in front of the handle.
  5. Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 5 中的图像 1,2 Dyson Cyclone V10 Absolute Motor Assembly Replacement: 步骤 5 中的图像 2,2
    • To separate the body of the vacuum from the motor assembly, gently pull them apart.
结论
3等其他人完成本指南。
Kuiyao
于09/19/22注册
243 声望
撰写一个指南
团队
York University, Team A-6, Morris Fall 2022 York University, Team A-6, Morris Fall 2022 的会员
YORK-MORRIS-F22SAG6
3 名成员
创作了1篇指南
2条评论
Hi I didnt realize u cant vaccum up flour and i vaccumed up quite a bit that spilled. When i went to clean the unit the actual motorhead. After removing the sliding case i stood the motorhead ip and talled the end and all kinds of flour came out the end tube of the motorhead. I kept tapping and more and more flour came out. Is it possible to take apart motorhead or should i take it to repair shop. Please advise
Vicki Benn - 回复
blow it out with an air compressor to get the flour all out...
Jeremy 888ferris - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 64
过去 30 天: 335
总计 5,235
