跳转到主内容
Dymo LabelManager 160 Charging Port Replacement
你所需要的
  1. Dymo LabelManager 160 Charging Port Replacement, Batteries: 步骤 1 中的图像 1,1
    • Place the device face-down to access the battery compartment.
  2. Dymo LabelManager 160 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. Dymo LabelManager 160 Charging Port Replacement, Keyboard: 步骤 3 中的图像 1,1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Dymo LabelManager 160 Charging Port Replacement: 步骤 4 中的图像 1,2 Dymo LabelManager 160 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Dymo LabelManager 160 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Dymo LabelManager 160 Charging Port Replacement: 步骤 6 中的图像 1,3 Dymo LabelManager 160 Charging Port Replacement: 步骤 6 中的图像 2,3 Dymo LabelManager 160 Charging Port Replacement: 步骤 6 中的图像 3,3
    • Gently remove the rubber keyboard from the device.
  7. Dymo LabelManager 160 Charging Port Replacement, Charging Port: 步骤 7 中的图像 1,1
    • Use wire cutters or scissors to cut the wires attached to the charging port, and remove the charging port.
  8. Dymo LabelManager 160 Charging Port Replacement: 步骤 8 中的图像 1,1
    • Use wire strippers to strip the end of each wire.
  9. Dymo LabelManager 160 Charging Port Replacement: 步骤 9 中的图像 1,1
    • Solder the black wire to the bottom-most node of the new charging port. Solder the red wire to the uppermost node of the new charging port. See the following link for soldering tips: 如何焊接和拆焊
结论
另外一个人完成了本指南。
Andrew Ozga
于03/02/17注册
170 声望
撰写一个指南
团队
IUPUI, Team S3-G4, Harley Spring 2017 IUPUI, Team S3-G4, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S3G4
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 893
