跳转到主内容
DualShock 4 CHU-ZCT2U Joystick Covers Replacement
你所需要的
  1. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel screws: 步骤 1 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel screws: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Separate the rear panel: 步骤 2 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Separate the rear panel: 步骤 2 中的图像 2,2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: 步骤 3 中的图像 1,3 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: 步骤 3 中的图像 2,3 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Release the plastic clips: 步骤 3 中的图像 3,3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel: 步骤 4 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the rear panel: 步骤 4 中的图像 2,2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 5 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the battery: 步骤 6 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the battery: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 7 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 7 中的图像 2,2
    • Remove the battery.
  8. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the motherboard: 步骤 8 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the motherboard: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
  9. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 9 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 9 中的图像 2,2
    • Remove the battery bracket.
  10. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 10 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
  11. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 11 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 11 中的图像 2,2
    • Separate the motherboard and midframe assembly from the front panel.
  12. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the joystick covers: 步骤 12 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Remove the joystick covers: 步骤 12 中的图像 2,2
    • Pull the right joystick cover straight off the joystick module to remove it.
  13. DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 13 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement: 步骤 13 中的图像 2,2
    • Pull the left joystick cover straight off the joystick module to remove it.
  14. DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Reassembly tip: 步骤 14 中的图像 1,2 DualShock 4 CHU-ZCT2U Joystick Covers Replacement, Reassembly tip: 步骤 14 中的图像 2,2
    • During reassembly, ensure the new joystick covers properly align with the shafts on the joystick modules before pressing them into place.
结论
33等其他人完成本指南。
Sam Omiotek
于02/25/19注册
84,642 声望
创作了290篇指南
一条评论
Are you able to replace the actual joystick with a diffrent one or are we only able to switch out covers?
Grant seward - 回复
添加评论
浏览统计数据:
过去 24 小时: 37
过去 7 天: 200
过去 30 天: 797
总计 23,140
