跳转到主内容
加入维修社区 - 创建账户
DualShock 4 Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. DualShock 4 Battery Replacement, DualShock 4 controller: 步骤 1 中的图像 1,1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
  2. DualShock 4 Battery Replacement, Separting the right and left handle: 步骤 2 中的图像 1,3 DualShock 4 Battery Replacement, Separting the right and left handle: 步骤 2 中的图像 2,3 DualShock 4 Battery Replacement, Separting the right and left handle: 步骤 2 中的图像 3,3
    • Start with the right handle:
    • Squeeze both sides of the right handle to create a small opening
    • Wedge an opening tool into the opening and slide it up towards the joystick
    • Pull down on the plier until you hear a click as it separtes from the controllers body.
    • Repeat these steps for the left handle.
  3. DualShock 4 Battery Replacement, Taking off the controllers cover: 步骤 3 中的图像 1,2 DualShock 4 Battery Replacement, Taking off the controllers cover: 步骤 3 中的图像 2,2
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the Share and Option button.
    • Split the plastic covers of the controller apart, but they will still be attached by circuit board ribbons.
  4. DualShock 4 Battery Replacement, Disconnecting the Ribbon: 步骤 4 中的图像 1,3 DualShock 4 Battery Replacement, Disconnecting the Ribbon: 步骤 4 中的图像 2,3 DualShock 4 Battery Replacement, Disconnecting the Ribbon: 步骤 4 中的图像 3,3
    • Detach the motherboard ribbon by pulling it straight out with your fingers.
    • Once the halves are separated, place the top of the controller off to the side.
  5. DualShock 4 Battery Replacement, Replacing the Battery: 步骤 5 中的图像 1,3 DualShock 4 Battery Replacement, Replacing the Battery: 步骤 5 中的图像 2,3 DualShock 4 Battery Replacement, Replacing the Battery: 步骤 5 中的图像 3,3
    • Using forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug.
    • Once the battery is unplugged, it can be lifted off of the controller.
结论
2等其他人完成本指南。
Chris marin
于08/24/22注册
148 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 565
