跳转到主内容
加入维修社区 - 创建账户
DualShock 3 Rear Cover Replacement
你所需要的
  1. DualShock 3 Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Rear Cover Replacement: 步骤 2 中的图像 1,1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Rear Cover Replacement: 步骤 3 中的图像 1,2 DualShock 3 Rear Cover Replacement: 步骤 3 中的图像 2,2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
结论
27等其他人完成本指南。
3指南评论
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
MasterKlaus Produtions (Swe0b) - 回复 分享
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
Aiodensghost - 分享
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 46
过去 30 天: 191
总计 26,369
