跳转到主内容
加入维修社区 - 创建账户
DualShock 3 Battery Replacement
你所需要的
  1. DualShock 3 Battery Replacement, Step 1: 步骤 1 中的图像 1,3 DualShock 3 Battery Replacement, Step 1: 步骤 1 中的图像 2,3 DualShock 3 Battery Replacement, Step 1: 步骤 1 中的图像 3,3
    • This is the Dualshock 3 controller
    • On the back of the controller, there will be five 7.2mm Phillips screws securing the body of the controller. (The five screws are circled in black.)
    • Remove each of the five screws from the back of the DualShock controller.
  2. DualShock 3 Battery Replacement, Step 2: 步骤 2 中的图像 1,1
    • Push the center of the rear cover (between the two analog sticks) and carefully lift the lower edge away from the rest of the controller.
  3. DualShock 3 Battery Replacement, Step 3: 步骤 3 中的图像 1,1
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, but be careful so that you won't pop off the #2 triggers.
    • Here is a DualShock trigger guide on the IFIXIT website in case you need to reattach the #2 triggers.
  4. DualShock 3 Battery Replacement, Step 4: 步骤 4 中的图像 1,1
    • Move the battery off the motherboard so you have enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement, Step 5: 步骤 5 中的图像 1,2 DualShock 3 Battery Replacement, Step 5: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully pull the battery connector away from the socket that is attached to the motherboard. ( Battery connector is circled in black.)
    • It may be safer to use a tool like tweezers or pliers to pull the battery connector out of the socket.
    • Now you can dispose of the old battery safely. For example taking old used batteries to a household hazardous waste facility.
结论
3等其他人完成本指南。
Marcus Aiken
于11/08/16注册
214 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 54
过去 30 天: 285
总计 4,576
