跳转到主内容
DualShock 3 Battery Replacement
你所需要的
  1. DualShock 3 Battery Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Battery Replacement: 步骤 2 中的图像 1,1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Battery Replacement: 步骤 3 中的图像 1,2 DualShock 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. DualShock 3 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
结论
161等其他人完成本指南。
20指南评论
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
Robert - 回复
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Raf - 回复
Try Amazon Cody
linzikerner - 回复
whats is amazon cody?
Albert Einstein -
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
geoquin4 - 回复
添加评论
浏览统计数据:
过去 24 小时: 80
过去 7 天: 346
过去 30 天: 1,609
总计 221,530
