跳转到主内容
加入维修社区 - 创建账户
DualSense Edge Front Trim Replacement
你所需要的
  1. DualSense Edge Front Trim Replacement, Remove the front trim: 步骤 1 中的图像 1,3 DualSense Edge Front Trim Replacement, Remove the front trim: 步骤 1 中的图像 2,3 DualSense Edge Front Trim Replacement, Remove the front trim: 步骤 1 中的图像 3,3
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
结论
Spencer Pennington
于09/09/23注册
24,362 声望
创作了126篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,329篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 59
总计 733
