跳转到主内容
Dreamax DMX-ST7A Motherboard Replacement
你所需要的
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: 步骤 3 中的图像 1,2 Dreamax DMX-ST7A Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: 步骤 4 中的图像 1,1
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: 步骤 6 中的图像 1,2 Dreamax DMX-ST7A Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: 步骤 7 中的图像 1,2 Dreamax DMX-ST7A Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: 步骤 8 中的图像 1,2 Dreamax DMX-ST7A Motherboard Replacement: 步骤 8 中的图像 2,2
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: 如何焊接和拆焊
结论
另外一个人完成了本指南。
Stacey Mattila
于03/18/15注册
543 声望
创作了5篇指南
团队
Michigan Tech, Team 1-4, Lauer Spring 2015 Michigan Tech, Team 1-4, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G4
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 314
