跳转到主内容
Drawstring Bag Tab Replacement
你所需要的
  1. Drawstring Bag Tab Replacement, Drawstring Bag Tab: 步骤 1 中的图像 1,3 Drawstring Bag Tab Replacement, Drawstring Bag Tab: 步骤 1 中的图像 2,3 Drawstring Bag Tab Replacement, Drawstring Bag Tab: 步骤 1 中的图像 3,3
    • Using your pen and ruler, draw two strips of 3.5" x 0.5" pieces of cloth.
    • Cut those two strips with your scissors.
  2. Drawstring Bag Tab Replacement: 步骤 2 中的图像 1,1
    • Align your two strips back to back.
    • Use two sewing pins to hold the strips in place for easy alignment during the sewing process.
    • Carefully handle the pins to avoid accidental punctures or injury. Use a thimble if needed.
  3. Drawstring Bag Tab Replacement: 步骤 3 中的图像 1,3 Drawstring Bag Tab Replacement: 步骤 3 中的图像 2,3 Drawstring Bag Tab Replacement: 步骤 3 中的图像 3,3
    • Using your thread and sewing needle, sew along the long edge in a straight line using a straight stitch.
    • Use a seam allowance of 1/8"
    • Repeat on the other side.
    • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if neede.
  4. Drawstring Bag Tab Replacement: 步骤 4 中的图像 1,2 Drawstring Bag Tab Replacement: 步骤 4 中的图像 2,2
    • Fold your strip around the cord to your drawstring bag to create a loop.
  5. Drawstring Bag Tab Replacement: 步骤 5 中的图像 1,3 Drawstring Bag Tab Replacement: 步骤 5 中的图像 2,3 Drawstring Bag Tab Replacement: 步骤 5 中的图像 3,3
    • Using the whipstitch technique, sew the two ends together.
    • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if needed.
  6. Drawstring Bag Tab Replacement: 步骤 6 中的图像 1,3 Drawstring Bag Tab Replacement: 步骤 6 中的图像 2,3 Drawstring Bag Tab Replacement: 步骤 6 中的图像 3,3
    • Take the sewn ends and insert them 1/4" into the ripped hole where the original tab was.
  7. Drawstring Bag Tab Replacement: 步骤 7 中的图像 1,3 Drawstring Bag Tab Replacement: 步骤 7 中的图像 2,3 Drawstring Bag Tab Replacement: 步骤 7 中的图像 3,3
    • Align the fabric with the seam line.
    • Using the whipstitch technique, sew it to the bag from the outside ensuring the stitches are along the seam.
  8. Drawstring Bag Tab Replacement: 步骤 8 中的图像 1,2 Drawstring Bag Tab Replacement: 步骤 8 中的图像 2,2
    • Now you have a working drawstring bag!
终点
Ava Overton
于02/19/25注册
157 声望
撰写一个指南
团队
UC Davis, Team 3-1, Andersen Winter 2025 UC Davis, Team 3-1, Andersen Winter 2025 的会员
UCD-ANDERSEN-W25S3G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 306
