跳转到主内容
Dragon Touch Y88X Plus Screen Replacement
你所需要的
  1. Dragon Touch Y88X Plus Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Use a plastic opening tool or spudger to carefully open the tablet's outer case. Start at the corners and work your way around. Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Screen Replacement: 步骤 2 中的图像 1,1
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
  3. Dragon Touch Y88X Plus Screen Replacement: 步骤 3 中的图像 1,1
    • Carefully peel the old battery from the adhesive using the Fixit pry tool.
    • Be very cautious not to puncture the battery
  4. Dragon Touch Y88X Plus Screen Replacement: 步骤 4 中的图像 1,2 Dragon Touch Y88X Plus Screen Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the three 4 mm screws located around the motherboard.
  5. Dragon Touch Y88X Plus Screen Replacement: 步骤 5 中的图像 1,2 Dragon Touch Y88X Plus Screen Replacement: 步骤 5 中的图像 2,2
    • Locate the ribbon cables that connect the screen to the tablet's motherboard and disconnect them. Make sure to note how these cables are attached so that you can reassemble them correctly later.
    • To remove the ribbons, flip the black switch where they are connected to the motherboard and gently pull the ribbons out.
  6. Dragon Touch Y88X Plus Screen Replacement: 步骤 6 中的图像 1,2 Dragon Touch Y88X Plus Screen Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool or spudger to pry the old screen away from the tablet carefully. Work your way around the edges, applying gentle pressure.
    • To remove the screen, you might need to utilize the metal spudger with the iFixit plastic pry tool.
结论
另外一个人完成了本指南。
Craig B
于10/30/23注册
262 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G4
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 235
