简介
Following this guide will allow you to replace the motherboard of your Dragon Touch Y88X Plus. This repair requires the use of a soldering iron. Be very cautious during the soldering process. The iron gets very hot and can cause injury. For more information on soldering, see the How to Solder and Desolder Connections guide.
你所需要的
Remove the back case using a plastic opening tool or spudger.
Start at the corners and work your way around the perimeter of the tablet.
2等其他人完成本指南。
