跳转到主内容
Dragon Touch Y88X Plus Motherboard Replacement
你所需要的
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: 步骤 3 中的图像 1,1
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: 步骤 4 中的图像 1,2 Dragon Touch Y88X Plus Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently lift the motherboard from the device.
结论
2等其他人完成本指南。
Cody Camara
于11/01/23注册
149 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 69
