跳转到主内容
Dragon Touch Y88X Plus Battery Replacement
你所需要的
  1. Dragon Touch Y88X Plus Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Battery Replacement: 步骤 2 中的图像 1,2 Dragon Touch Y88X Plus Battery Replacement: 步骤 2 中的图像 2,2
    • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
    • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
  3. Dragon Touch Y88X Plus Battery Replacement: 步骤 3 中的图像 1,2 Dragon Touch Y88X Plus Battery Replacement: 步骤 3 中的图像 2,2
    • Use a soldering iron to disconnect each connector individually from the motherboard.
  4. Dragon Touch Y88X Plus Battery Replacement: 步骤 4 中的图像 1,1
    • Remove any adhesive from the battery.
    • Remove the battery.
结论
2等其他人完成本指南。
Bavly Aziz
于10/30/23注册
195 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 106
