跳转到主内容
Dragon Touch A1x Plus Cameras Replacement
你所需要的
  1. Dragon Touch A1x Plus Cameras Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Cameras Replacement: 步骤 2 中的图像 1,2 Dragon Touch A1x Plus Cameras Replacement: 步骤 2 中的图像 2,2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Cameras Replacement: 步骤 3 中的图像 1,1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Cameras Replacement: 步骤 4 中的图像 1,1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Cameras Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Cameras Replacement: 步骤 6 中的图像 1,2 Dragon Touch A1x Plus Cameras Replacement: 步骤 6 中的图像 2,2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  7. Dragon Touch A1x Plus Cameras Replacement, Cameras: 步骤 7 中的图像 1,2 Dragon Touch A1x Plus Cameras Replacement, Cameras: 步骤 7 中的图像 2,2
    • Remove black tape holding the cameras to the motherboard.
  8. Dragon Touch A1x Plus Cameras Replacement: 步骤 8 中的图像 1,2 Dragon Touch A1x Plus Cameras Replacement: 步骤 8 中的图像 2,2
    • Use your fingernail to flip up the small locking flap on the ZIF connector.
    • Pull the ribbon cable from the ZIF connector.
  9. Dragon Touch A1x Plus Cameras Replacement: 步骤 9 中的图像 1,1
    • Remove the front camera from the device using your fingers.
  10. Dragon Touch A1x Plus Cameras Replacement: 步骤 10 中的图像 1,2 Dragon Touch A1x Plus Cameras Replacement: 步骤 10 中的图像 2,2
    • Melt the glue holding the rear camera in place using a hair dryer.
    • Insert the metal spludger under the rear camera and pry it free from the device.
结论
Josh Null
于03/21/18注册
313 声望
创作了3篇指南
团队
IUPUI, Team S5-G5, Baechle Spring 2018 IUPUI, Team S5-G5, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 166
