跳转到主内容
Dragon Touch A1x Plus Battery Replacement
你所需要的
  1. Dragon Touch A1x Plus Battery  Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Battery  Replacement: 步骤 2 中的图像 1,2 Dragon Touch A1x Plus Battery  Replacement: 步骤 2 中的图像 2,2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Battery  Replacement: 步骤 3 中的图像 1,1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Battery  Replacement: 步骤 4 中的图像 1,1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Battery  Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Battery  Replacement: 步骤 6 中的图像 1,2 Dragon Touch A1x Plus Battery  Replacement: 步骤 6 中的图像 2,2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
结论
Josh Null
于03/21/18注册
313 声望
创作了3篇指南
团队
IUPUI, Team S5-G5, Baechle Spring 2018 IUPUI, Team S5-G5, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G5
3 名成员
创作了6篇指南
一条评论
where can you find a replacement battery for this tablet?
Lupe Rdrgz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 1,835
