跳转到主内容
加入维修社区 - 创建账户
Door Mirror Replacement
你所需要的
  1. Door Mirror Replacement, Door Mirror: 步骤 1 中的图像 1,1
    • Use a screwdriver to remove the two brackets securing the top of the mirror.
    • The mirror will fall forward once the two top brackets are released; be sure to support the mirror as you unscrew the brackets.
    • The type of screwdriver needed will depend on your specific brackets.
  2. Door Mirror Replacement: 步骤 2 中的图像 1,1
    • Lift the broken mirror off of the door.
    • Remove any cardboard or other cushioning (if any) from the door.
  3. Door Mirror Replacement: 步骤 3 中的图像 1,1
    • Loosen, but don't remove, the bottom brackets to accommodate the width of the new mirror.
  4. Door Mirror Replacement: 步骤 4 中的图像 1,1
    • If you have new mirror supports, then remove the old brackets entirely and replace them with the new brackets.
  5. Door Mirror Replacement: 步骤 5 中的图像 1,1
    • Replace any cushioning behind the mirror.
    • While supporting the top of the mirror, set the mirror into the bottom brackets, then tighten the brackets.
  6. Door Mirror Replacement: 步骤 6 中的图像 1,1
    • Replace the top brackets and tighten them to full secure the mirror.
结论
Enjoy your new mirror!
Seth Wanderman
于02/28/22注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 45
总计 997
