跳转到主内容
Disassembling iPhone 4S Back Camera
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Battery: 步骤 1 中的图像 1,1
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Back Camera: 步骤 2 中的图像 1,1
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Back Camera: 步骤 3 中的图像 1,1
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Back Camera: 步骤 4 中的图像 1,2 Disassembling iPhone 4S Back Camera: 步骤 4 中的图像 2,2
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Back Camera: 步骤 5 中的图像 1,1
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Back Camera: 步骤 6 中的图像 1,1
    • Unscrew the 4 phillips screws holding the shield covering 6 of the 8 connectors.
    • Make sure to keep track of which screws are which, they very by tenths of a millimeter.
  7. Disassembling iPhone 4S Back Camera: 步骤 7 中的图像 1,2 Disassembling iPhone 4S Back Camera: 步骤 7 中的图像 2,2
    • Using a plastic opening tool, pry the back camera connector from the logic board.
    • Be careful not to lose the small square peice of plastic covering the bottom of the camera, it comes off very easily.
结论
4等其他人完成本指南。
Chandler Skinner
于10/15/11注册
3,710 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 2,688
