跳转到主内容
Disassembling Planet Eclipse Geo3 Body
你所需要的
  1. Disassembling Planet Eclipse Geo3 Body, Grip: 步骤 1 中的图像 1,2 Disassembling Planet Eclipse Geo3 Body, Grip: 步骤 1 中的图像 2,2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Disassembling Planet Eclipse Geo3 Body: 步骤 2 中的图像 1,2 Disassembling Planet Eclipse Geo3 Body: 步骤 2 中的图像 2,2
    • Pull the grip away from the frame.
  3. Disassembling Planet Eclipse Geo3 Body: 步骤 3 中的图像 1,2 Disassembling Planet Eclipse Geo3 Body: 步骤 3 中的图像 2,2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Disassembling Planet Eclipse Geo3 Body, Macroline: 步骤 4 中的图像 1,3 Disassembling Planet Eclipse Geo3 Body, Macroline: 步骤 4 中的图像 2,3 Disassembling Planet Eclipse Geo3 Body, Macroline: 步骤 4 中的图像 3,3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Disassembling Planet Eclipse Geo3 Body: 步骤 5 中的图像 1,3 Disassembling Planet Eclipse Geo3 Body: 步骤 5 中的图像 2,3 Disassembling Planet Eclipse Geo3 Body: 步骤 5 中的图像 3,3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Disassembling Planet Eclipse Geo3 Body, Body: 步骤 6 中的图像 1,3 Disassembling Planet Eclipse Geo3 Body, Body: 步骤 6 中的图像 2,3 Disassembling Planet Eclipse Geo3 Body, Body: 步骤 6 中的图像 3,3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Disassembling Planet Eclipse Geo3 Body: 步骤 7 中的图像 1,3 Disassembling Planet Eclipse Geo3 Body: 步骤 7 中的图像 2,3 Disassembling Planet Eclipse Geo3 Body: 步骤 7 中的图像 3,3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
结论
Rett Triplett
于10/18/13注册
801 声望
创作了8篇指南
团队
Clemson, Team 13-6, Benson Fall 2013 Clemson, Team 13-6, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G6
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 730
