跳转到主内容
加入维修社区 - 创建账户
Disassembling Microsoft Surface 3 Casing
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Disassembling Microsoft Surface 3 Casing, Casing: 步骤 1 中的图像 1,2 Disassembling Microsoft Surface 3 Casing, Casing: 步骤 1 中的图像 2,2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Disassembling Microsoft Surface 3 Casing: 步骤 2 中的图像 1,2 Disassembling Microsoft Surface 3 Casing: 步骤 2 中的图像 2,2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Disassembling Microsoft Surface 3 Casing: 步骤 3 中的图像 1,2 Disassembling Microsoft Surface 3 Casing: 步骤 3 中的图像 2,2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Disassembling Microsoft Surface 3 Casing: 步骤 4 中的图像 1,1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
结论
Harold Hall
于10/08/15注册
1,329 声望
创作了3篇指南
团队
Cal Poly, Team 5-12, Maness Fall 2015 Cal Poly, Team 5-12, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G12
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 217
