本指南有最近更改,您可查看未经巡查的最新版本。
简介
The plastic edge cover needs to be removed to get to some components.
你所需要的
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
即将完成!
结论
