跳转到主内容
Disassembling Canon Powershot SD880 Logic Board
你所需要的
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: 步骤 1 中的图像 1,3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: 步骤 1 中的图像 2,3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: 步骤 2 中的图像 1,3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: 步骤 2 中的图像 2,3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: 步骤 2 中的图像 3,3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: 步骤 3 中的图像 1,2 Disassembling Canon Powershot SD880 Logic Board, Top Panel: 步骤 3 中的图像 2,2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: 步骤 4 中的图像 1,1
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: 步骤 5 中的图像 1,2 Disassembling Canon Powershot SD880 Logic Board: 步骤 5 中的图像 2,2
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
结论
Juan Miguel
于01/13/11注册
101 声望
撰写一个指南
团队
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G3
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 2,019
