跳转到主内容
Disassembling Canon PowerShot A590 IS Front Cover
你所需要的
  1. Disassembling Canon PowerShot A590 IS Front Cover, Batteries: 步骤 1 中的图像 1,2 Disassembling Canon PowerShot A590 IS Front Cover, Batteries: 步骤 1 中的图像 2,2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
    Can the hatch be replaced. The piece that holds the hatch is broken.
    alisonbforman46 - 回复
    I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
    Spud Head - 回复
  2. Disassembling Canon PowerShot A590 IS Front Cover: 步骤 2 中的图像 1,1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Disassembling Canon PowerShot A590 IS Front Cover: 步骤 3 中的图像 1,1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Disassembling Canon PowerShot A590 IS Front Cover, Back Cover: 步骤 4 中的图像 1,1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Disassembling Canon PowerShot A590 IS Front Cover: 步骤 5 中的图像 1,1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Disassembling Canon PowerShot A590 IS Front Cover: 步骤 6 中的图像 1,1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Disassembling Canon PowerShot A590 IS Front Cover: 步骤 7 中的图像 1,1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
    Ik kan de achterkant er niet afkrijgen.
    De onderzijde gaat wel wat open, maar wat ik ook probeer de bovenzijde blijft op de een of andere manier haken en geeft geen krimp.
    Hopelijk hooft iemand hier iets op verzonnen om hem wel open te kunnen krijgen.
    mvrgr WH
    W.H. - 回复
  8. Disassembling Canon PowerShot A590 IS Front Cover, Remove Lens Cover: 步骤 8 中的图像 1,1
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
  9. Disassembling Canon PowerShot A590 IS Front Cover, Remove Front Cover: 步骤 9 中的图像 1,2 Disassembling Canon PowerShot A590 IS Front Cover, Remove Front Cover: 步骤 9 中的图像 2,2
    • Remove the front cover of the camera.
    • This may require a bit of force.
结论
5等其他人完成本指南。
Zach
于10/11/10注册
281 声望
创作了6篇指南
团队
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G19
4 名成员
创作了14篇指南
3条评论
The photos do not show a camera strap, and the instructions don't mention it. Before starting disassembly, I advise removing the camera strap. It make it easier to remove and re-attach the back cover.
jwoconnor - 回复
A handy guide. I had an A590IS with a broken battery door latch on the camera body, and I managed to obtain a dead A590IS with a fully intact latch for free. So using this guide I swapped the body shells over! All fixed and working again!
brianinnes81 - 回复
l cannot get an answer to my question on why my Canon A590 will not power on.
burks817 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 32
总计 14,657
