跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Disassembling Canon Pixma MP480 Rear and Side Panel
你所需要的
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: 步骤 1 中的图像 1,2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: 步骤 1 中的图像 2,2
    • Remove the following two Phillips screws:
    • Two 7.85 mm Phillips #1 screws
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 2 中的图像 1,1
    • Pull the back cover off by lifting up on the cover.
    • You may need to pull firmly as it requires quite a bit of force.
    "quite a bit of force" is almost an understatement, I found 2 clips along the bottom of that rear piece, one at the far left one around the middle (indicated by an arrow on the underside of the machine) - undoing these required much persistence with a screwdriver
    Perhaps Fuzz - 回复
    Thank you, Perhaps Fuzz. Thank you.
    Marji Zintz -
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 3 中的图像 1,1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 4 中的图像 1,1
    • Lift the scanner compartment.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 5 中的图像 1,1
    • After opening up the scanner compartment, make sure the blue lever locks into place, keeping the compartment open.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 6 中的图像 1,2 Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 6 中的图像 2,2
    • Push the blue lever back while twisting it clockwise in order to remove the lever from its slot.
    • After removing the lever, close the scanner compartment and the scanner cover.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 7 中的图像 1,2 Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to pry open the side cover.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 8 中的图像 1,2 Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 8 中的图像 2,2
    • Flip the printer so that you are facing the underside.
    • Use the plastic opening tool to remove the corner of the side panel from the pin.
    • Plastic pin.
  9. Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 9 中的图像 1,2 Disassembling Canon Pixma MP480 Rear and Side Panel: 步骤 9 中的图像 2,2
    • Using the plastic opening tool, remove the side panel by loosening it from the bottom of the printer.
结论
6等其他人完成本指南。
Kevin Cole
于01/17/13注册
116 声望
撰写一个指南
团队
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G41
4 名成员
创作了6篇指南
2条评论
Where is the rest of disassembly?
bill roberts - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 27
总计 21,170
