跳转到主内容
Dirt Devil Scorpion Quick Flip Power Cord Replacement
你所需要的
  1. Dirt Devil Scorpion Quick Flip Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • While holding the device by the handle, press the button on the left-hand side of the vacuum handle in order to release the nozzle from the body.
  2. Dirt Devil Scorpion Quick Flip Power Cord Replacement: 步骤 2 中的图像 1,2 Dirt Devil Scorpion Quick Flip Power Cord Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 Screwdriver, remove all six of the 4 mm screws holding the shell together.
  3. Dirt Devil Scorpion Quick Flip Power Cord Replacement: 步骤 3 中的图像 1,1
    • Using utility scissors, cut the black and white cables approximately an inch and a half above where they connect to the faulty power cord.
  4. Dirt Devil Scorpion Quick Flip Power Cord Replacement: 步骤 4 中的图像 1,1
    • Using a soldering iron, fuse the black and white cables from the new power cord to where the previous cord was cut away.
    • Using electrical tape, cover the exposed area.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 286
