跳转到主内容
Dirt Devil Scorpion Quick Flip Circuit Board Replacement
你所需要的
  1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Push the button on the left-hand side of the handle.
    • Remove the filter holder from the main body.
  2. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: 步骤 2 中的图像 1,2 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Remove the first two 4 mm screws using a Phillips #1 Screwdriver.
    • Remove the last four 4 mm screws using a Phillips #1 Screwdriver.
    • Carefully take the device a part.
  3. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: 步骤 3 中的图像 1,2 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Identify the circuit board located in the inside of the handle.
    • Remove the gray switch located on top of the circuit board.
    • Using utility scissors, cut the wires 1/2 inch away from the circuit board.
  4. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: 步骤 4 中的图像 1,2 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Solder the new circuit board to the existing wires.
    • Using electrical tape or heat shrink tubing, cover the soldered area.
    • Place the new circuit board into the correct spot inside the handle.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 136
