简介
This guide will help users replace damaged or malfunctioning internal dual speakers on the Digitech XC-5206 Bluetooth speaker. Please refer to troubleshooting page before beginning replacement guide steps.
你所需要的
Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
Angle the spudger and use your fingers to pry the panel off.
Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
OR grab ahold of the silver tab to pull the speaker face out. This may require force.
Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
另外一个人完成了本指南。
