跳转到主内容
Digitech XC- 5206 Dual Speaker Replacement
你所需要的
  1. Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: 步骤 1 中的图像 1,2 Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: 步骤 1 中的图像 2,2
    • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
    • Angle the spudger and use your fingers to pry the panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Dual Speaker Replacement: 步骤 2 中的图像 1,3 Digitech XC- 5206 Dual Speaker Replacement: 步骤 2 中的图像 2,3 Digitech XC- 5206 Dual Speaker Replacement: 步骤 2 中的图像 3,3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Dual Speaker Replacement: 步骤 3 中的图像 1,2 Digitech XC- 5206 Dual Speaker Replacement: 步骤 3 中的图像 2,2
    • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
    • Push speaker bulbs forward and out of slot.
  4. Digitech XC- 5206 Dual Speaker Replacement: 步骤 4 中的图像 1,2 Digitech XC- 5206 Dual Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 239
