1. With the appropriate tools on hand, you want to look for the charging port. Once you have located your charging port, to the right of it you will be able to insert the prying tool into the crack between the case and the display border. Now continue to pry the case with the same technique all around.
    • With the appropriate tools on hand, you want to look for the charging port.
    • Once you have located your charging port, to the right of it you will be able to insert the prying tool into the crack between the case and the display border.
    • Now continue to pry the case with the same technique all around.
    • After prying all around the device, you will be able to separate the back cover from the display , which holds all the components.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Once you have opened the case completely, you will be able to see the battery. There will be pieces of yellow tape holding the cables and other components in place. Locate and peel back the tape enough so that the battery is not held in place by it.
    • Once you have opened the case completely, you will be able to see the battery.
    • There will be pieces of yellow tape holding the cables and other components in place.
    • Locate and peel back the tape enough so that the battery is not held in place by it.
  4. You want to leave the tape attached to either the circuit board, or the battery its self. Now use your spudger as a prying tool to insert underneath the battery and separate it from the back of the display. Once you have entirely separated the battery from the back of the display, it will still be attached to the circuit board by the power cables.
    • You want to leave the tape attached to either the circuit board, or the battery its self.
    • Now use your spudger as a prying tool to insert underneath the battery and separate it from the back of the display.
    • Once you have entirely separated the battery from the back of the display, it will still be attached to the circuit board by the power cables.
    • To remove the cables from the circuit board, a soldering tool will be required. You will also need to solder the new battery cables back onto the circuit board.
结论
另外一个人完成了本指南。
Miguel A Rodriguez
于2014年10月25日注册
592 信誉积分
创作了4篇指南
团队
Gateway, Team 1-6, Johnson Fall 2014 Gateway, Team 1-6, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G6
2 名成员
创作了4篇指南
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 16
总计 3,365
