跳转到主内容
Digiland DL1168A Rear Case Replacement
你所需要的
  1. Digiland DL1168A Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Rear Case Replacement: 步骤 2 中的图像 1,2 Digiland DL1168A Rear Case Replacement: 步骤 2 中的图像 2,2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Rear Case Replacement: 步骤 3 中的图像 1,2 Digiland DL1168A Rear Case Replacement: 步骤 3 中的图像 2,2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 115
