跳转到主内容
加入维修社区 - 创建账户
Digiland DL1168A Battery Replacement
你所需要的
    1. Digiland DL1168A Battery Replacement, Rear Case: 步骤 1 中的图像 1,1
      • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      询问修复机器人
      添加评论
    2. Digiland DL1168A Battery Replacement: 步骤 2 中的图像 1,2 Digiland DL1168A Battery Replacement: 步骤 2 中的图像 2,2
      • Carefully lift back panel away from the body of the device.
      • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
      询问修复机器人
      添加评论
    3. Digiland DL1168A Battery Replacement: 步骤 3 中的图像 1,2 Digiland DL1168A Battery Replacement: 步骤 3 中的图像 2,2
      • Desolder the four wires connecting the rear case to the motherboard.
      • Disconnect the wires from the motherboard.
      • Remove the rear case from the device.
      询问修复机器人
      添加评论
    1. Digiland DL1168A Battery Replacement, Battery: 步骤 4 中的图像 1,3 Digiland DL1168A Battery Replacement, Battery: 步骤 4 中的图像 2,3 Digiland DL1168A Battery Replacement, Battery: 步骤 4 中的图像 3,3
      • Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
      • The soldering tool is hot, and will burn. Follow this link for instructions on 如何焊接和拆焊.
      询问修复机器人
      添加评论
    2. Digiland DL1168A Battery Replacement: 步骤 5 中的图像 1,2 Digiland DL1168A Battery Replacement: 步骤 5 中的图像 2,2
      • Using an opening tool, separate the battery from the tablet.
      • Follow the edge of the battery to loosen the glue.
      询问修复机器人
      添加评论
    3. Digiland DL1168A Battery Replacement: 步骤 6 中的图像 1,3 Digiland DL1168A Battery Replacement: 步骤 6 中的图像 2,3 Digiland DL1168A Battery Replacement: 步骤 6 中的图像 3,3
      • Once the glue is loosened, pry the battery away from the screen.
      • Pulling on the battery may cause you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 640
