跳转到主内容
DigiTech RP70 Amp/Mixer Switch Replacement
你所需要的
  1. DigiTech RP70  Amp/Mixer Switch Replacement, Motherboard: 步骤 1 中的图像 1,2 DigiTech RP70  Amp/Mixer Switch Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70  Amp/Mixer Switch Replacement: 步骤 2 中的图像 1,2 DigiTech RP70  Amp/Mixer Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70  Amp/Mixer Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70  Amp/Mixer Switch Replacement: 步骤 4 中的图像 1,1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70  Amp/Mixer Switch Replacement, Amp/Mixer Switch: 步骤 5 中的图像 1,1
    • Desolder the back of the motherboard where you want to replace the switch.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 406
