跳转到主内容
Diagnosing and Erasing Hard Drives
你所需要的
  1. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 步骤 1 中的图像 1,3 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 步骤 1 中的图像 2,3 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 步骤 1 中的图像 3,3
    • If the HDD/SSD is not installed in a PC, a USB drive adapter (SATA) can be used. For NVMe and NGFF M.2 SSDs, a specific enclosure is required.
    • If the hard drive is not installed and you do not have a USB adapter, it can be plugged into a motherboard.
  2. Diagnosing and Erasing Hard Drives, (Ubuntu) Check the POH/POC: 步骤 2 中的图像 1,3 Diagnosing and Erasing Hard Drives, (Ubuntu) Check the POH/POC: 步骤 2 中的图像 2,3 Diagnosing and Erasing Hard Drives, (Ubuntu) Check the POH/POC: 步骤 2 中的图像 3,3
    • While high hours are not an indication of failure, these drives are more likely to fail.
    • GSmartControl can be used in Ubuntu if you cannot read the output from Disks.
    • Boot your system into a live Ubuntu session. Locate the Disks application and select the hard disk you want to test.
    • From the drop-down menu, select SMART Data and Self Tests. This will pull up the SMART data.
    • Locate the following SMART attributes: Power On Hours and Power Cycle Count.
  3. Diagnosing and Erasing Hard Drives, (Ubuntu) Check the reallocated sectors and test the drive: 步骤 3 中的图像 1,3 Diagnosing and Erasing Hard Drives, (Ubuntu) Check the reallocated sectors and test the drive: 步骤 3 中的图像 2,3 Diagnosing and Erasing Hard Drives, (Ubuntu) Check the reallocated sectors and test the drive: 步骤 3 中的图像 3,3
    • If Reallocated Sector Count is highlighted and the number is high, replace the drive. Use SMART Extended for accuracy. You will lose capacity and these drives often fail without warning!
    • Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
    • To run a SMART Extended Self-Test, left click Start Self-Test. Select Extended from the drop-down menu.
  4. Diagnosing and Erasing Hard Drives, (Parted Magic) Check the POH/POC: 步骤 4 中的图像 1,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Check the POH/POC: 步骤 4 中的图像 2,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Check the POH/POC: 步骤 4 中的图像 3,3
    • Select Disks from the desktop to open GSmartControl.
    • Select the hard disk you want to test. Click Attributes to read the SMART data.
    • Locate the following attributes: Power On Time and Power Cycle Count.
  5. Diagnosing and Erasing Hard Drives, (Parted Magic) Check the reallocated sectors and test the drive: 步骤 5 中的图像 1,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Check the reallocated sectors and test the drive: 步骤 5 中的图像 2,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Check the reallocated sectors and test the drive: 步骤 5 中的图像 3,3
    • In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count.
    • To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
  6. Diagnosing and Erasing Hard Drives, (Parted Magic) Check the error log: 步骤 6 中的图像 1,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Check the error log: 步骤 6 中的图像 2,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Check the error log: 步骤 6 中的图像 3,3
    • Use the error log and SMART data together to diagnose drive problems.
    • Check the error log for drive errors. Click the Error log tab, and review the logs.
    • In the Error log, review the available errors. Read these logs if any are found.
  7. Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 步骤 7 中的图像 1,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 步骤 7 中的图像 2,3 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 步骤 7 中的图像 3,3
    • When possible, avoid sector wiping SSDs. This will reduce the drive liftetime and can be drastic on older 75TBW lifetime drives.
    • Your erase options are limited to the Security Set options supported by your drive.
    • Drives without ATA Secure Erase will need to be erased externally. Select External and choose Nwipe. Run the DoD Short command (3 wipes+drive blanking).
    • If your drive has a buggy ATA Secure Erase implementation, choose External and erase the drive with Nwipe. SSDs should only be erased with the Secure Erase command.
    • For NVMe SSDs, the best option is to use NVMe Secure Erase.
终点
Nick
于11/10/09注册
85,149 声望
创作了50篇指南
团队
Master Techs Master Techs 的会员
Community
314 名成员
创作了1,323篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 1,499
