简介
Usa esta guía para desensamblar todas o cualquiera de las partes de la Game Boy Advance
你所需要的
Quita la tapa trasera de la batería pellizcando la pestaña y tirando hacia fuera.
Utiliza un spudger de plástico/pinzas/uñas para desbloquear el cable plano de la pantalla tirando suavemente de las pestañas laterales hacia arriba (hacia el borde superior de la placa base)
Una vez el cable plano de la pantalla se ha desbloqueado, el cable debería deslizarse con facilidad y puede quitarse sin usar fuerza con unas pinzas o los dedos.
Guide does not indicate that the ribbon cable port should be UNLATCHED before attempting to remove the ribbon cable, I strongly suggest revising this as someone unfamiliar with these style of ports may assume that the ribbon cable is a compression fit and just needs to be "pulled" free of the port.
This is a terrible idea that will potentially result in tearing the ribbon! Please consider revising guide to add a step to indicate the proper method/detail for unlatching the LCD ribbon port! Thanks :)
Usa el spudger para levantar la pantalla de la carcasa frontal. Coloca espátula en el espacio a la izquierda del pad direccional.
This is a BAD place to pry on a functioning LCD. I used this exact method, slowly and carefully, and my LCD shattered.
Instead, remove the lens (it’s worth it to sacrifice the lens adhesive to save your LCD), and gently and slowly press with a gloved thumb on a corner to push it through from the front of the Game Boy. Let the adhesive release itself, don’t force it. If the room is super quiet, you should be able to hear a faint peeling sound, even if you can’t see anything moving. That means you’re doing it right; just wait and it will release.
Actually you can just pry under the ribbon cable. The LCD has a metal frame there that allowed me to slowly and carefully pry from that point without (re)breaking my LCD.
Yep. Same thing just happened to me :(
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
I dont understand. The items in “Tools featured in this teardown" is different from the tools written on the article e.g. Y0 in “featured" but Y1 in the “article”.
Great guide. My dumb ass didn’t see the screws holding the circuit board to the front shell lmao
RikaSprout - 回复
What is the cpu
How do you remove the CPU and SRAM chips?
