简介
This guide will provide instructions on how to remove and replace the Trackpad for the Dell XPS 15 9575. The trackpad is responsible for controlling the cursor on screen and is a major form of input for the laptop. Issues with the trackpad include erroneous click input, unresponsive clicks, cursor drift, and any other input that doesn’t match what’s intended by the user.
Though issues with the trackpad can be fairly obvious, check out the Dell XPS 9575 Troubleshooting Page for some additional information on potential issues pertaining to this component.
你所需要的
Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Use the Phillips #0 screwdriver to remove all four silver 3.2mm screws fastening the interconnect cable.
Use the Phillips #0 screwdriver to remove the two silver 3.2mm screws located in the two top corners of the trackpad.
另外一个人完成了本指南。
