跳转到主内容
Dell XPS 15 9575 Solid State Drive Replacement
你所需要的
  1. Dell XPS 15 9575 Solid State Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Dell XPS 15 9575 Solid State Drive Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Dell XPS 15 9575 Solid State Drive Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Solid State Drive Replacement: 步骤 2 中的图像 1,1
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 1,3 Dell XPS 15 9575 Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 2,3 Dell XPS 15 9575 Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 3,3
    • Use the Phillips #0 Screwdriver to remove a single 3.2mm screw from the SSD Drive.
    • You will know the drive is released when the side holding the screw raises.
  4. Dell XPS 15 9575 Solid State Drive Replacement: 步骤 4 中的图像 1,2 Dell XPS 15 9575 Solid State Drive Replacement: 步骤 4 中的图像 2,2
    • Carefully slide the SSD from its port, removing it from the device.
结论
2等其他人完成本指南。
2条评论
After replacing the SSD 256GB to 1TB the Power Led started blinking yellow 4 times, white one time when powered by the AC adapter. The internal battery seemes to be disabled somehow. Any suggestions whats missing? Open cover detection maybe? There are no error messages from the bios, windows is running without problems.
micky mouse - 回复
This seemed to be caused by accidentially switching of the little white switch right beside the ssd when placing the ssd into the connector. After switching it on again, it worked as before, no led blinking and running from battery again.
micky mouse -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 52
总计 2,332
