简介
This guide will teach you how to replace the battery in your Dell XPS 15 9570.
This process will require a T5 Torx Screwdriver, an iFixit Opening Tool, Phillips #00 Screwdriver, and a replacement battery.
Batteries are what let your laptop hold power. A bad battery can lead to many problems. Here are some signs that your battery may need replacing:
- The laptop will not stay on, or cannot run without being plugged-in. Constant shutting down is a major sign of battery issues.
- The laptop will not charge properly.
- If the battery appears to have become swollen or to have leaked, BE EXTRA CAREFUL.
If your battery is swollen check out this article below:
What to Do With a Swollen iPhone Battery
(It says iPhone, but the same process goes for any lithium-ion battery)
Before starting the repair, swollen battery or not, unplug the device and let the battery's charge reach 0%.
Remember that after you have successfully replaced the battery (which we are sure you will) please recycle it: How to Properly Recycle Your Old iPhone Battery
(Again it says iPhone, but the same process goes for any lithium-ion battery).
你所需要的
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
6等其他人完成本指南。
