跳转到主内容
Dell XPS 15 9570 Battery Replacement
你所需要的
  1. Dell XPS 15 9570 Battery Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Battery Replacement: 步骤 2 中的图像 1,3 Dell XPS 15 9570 Battery Replacement: 步骤 2 中的图像 2,3 Dell XPS 15 9570 Battery Replacement: 步骤 2 中的图像 3,3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Battery Replacement: 步骤 3 中的图像 1,2 Dell XPS 15 9570 Battery Replacement: 步骤 3 中的图像 2,2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Battery Replacement: 步骤 7 中的图像 1,1
    • With your hands, pick up and remove the battery from the system.
结论
12等其他人完成本指南。
Clay Caldwell
于09/03/21注册
357 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 70
过去 30 天: 343
总计 18,686
