跳转到主内容
Dell XPS 15 9510 RAM Replacement
你所需要的
  1. Dell XPS 15 9510 RAM Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 RAM Replacement: 步骤 2 中的图像 1,1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 RAM Replacement: 步骤 3 中的图像 1,1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Using both hands, pull the clips that hold the RAM in place.
  5. Dell XPS 15 9510 RAM Replacement: 步骤 5 中的图像 1,2 Dell XPS 15 9510 RAM Replacement: 步骤 5 中的图像 2,2
    • Gently, with both hands, pull the RAM up at a 45º angle and take out the RAM.
    • Repeat the same process with the other RAM.
结论
另外一个人完成了本指南。
Bethany Wright
于07/13/23注册
403 声望
创作了3篇指南
团队
IUPUI, Team 2-1, Harley Summer 2023 IUPUI, Team 2-1, Harley Summer 2023 的会员
IUPUI-HARLEY-SU23S2G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 38
总计 552
