简介
The device featured in this replacement guide is the Dell XPS 14 L421X. This guide will assist the user in removing and replacing the laptop's speaker system. There are no special skills or requirements for this guide. The speaker will likely need to be replaced if you are experiencing audio system issues. For more troubleshooting information, refer to the troubleshooting page. Before fully removing the speakers, make sure you check to ensure that the speaker is connected to the device, as these symptoms may also be due to a loose cable or plug. Before following these steps, it is crucial that you ground yourself. You can do so by wearing an ESD-safe anti-static wrist strap.
你所需要的
Position the computer back side up so that the “XPS” logo is facing you.
Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
Flip over the back panel so that the interior of the panel is facing up.
Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
Remove the black plastic cover that holds the disk in place.
Remove the back panel.
Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
