跳转到主内容
Dell XPS 14 Speaker Replacement
你所需要的
  1. Dell XPS 14 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 Speaker Replacement: 步骤 2 中的图像 1,3 Dell XPS 14 Speaker Replacement: 步骤 2 中的图像 2,3 Dell XPS 14 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 Speaker Replacement: 步骤 3 中的图像 1,2 Dell XPS 14 Speaker Replacement: 步骤 3 中的图像 2,2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 Speaker Replacement: 步骤 4 中的图像 1,3 Dell XPS 14 Speaker Replacement: 步骤 4 中的图像 2,3 Dell XPS 14 Speaker Replacement: 步骤 4 中的图像 3,3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Dell XPS 14 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 Speaker Replacement: 步骤 6 中的图像 1,2 Dell XPS 14 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
结论
Gabriella Monico
于03/23/22注册
457 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-3, Botvin Spring 2022 UMass Dartmouth, Team 1-3, Botvin Spring 2022 的会员
UMASSD-BOTVIN-S22S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 202
