跳转到主内容
Dell XPS 14 L401X Battery Replacement
你所需要的
  1. Dell XPS 14 L401X Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell XPS 14 L401X Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Mark
于10/19/17注册
655 声望
创作了6篇指南
团队
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G3
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 718
