跳转到主内容
加入维修社区 - 创建账户
Dell XPS 13 Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Dell XPS 13 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell XPS 13 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Battery Replacement: 步骤 2 中的图像 1,2 Dell XPS 13 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Battery Replacement: 步骤 4 中的图像 1,1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover.
  6. Dell XPS 13 Battery Replacement, Battery: 步骤 6 中的图像 1,2 Dell XPS 13 Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  7. Dell XPS 13 Battery Replacement: 步骤 7 中的图像 1,2 Dell XPS 13 Battery Replacement: 步骤 7 中的图像 2,2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • Do not pull up.
  8. Dell XPS 13 Battery Replacement: 步骤 8 中的图像 1,1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
    询问修复机器人
  9. Dell XPS 13 Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the battery.
    询问修复机器人
结论
23等其他人完成本指南。
Ella Herrmann
于04/24/17注册
1,744 声望
创作了3篇指南
团队
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G6
5 名成员
创作了30篇指南
6指南评论
There is a #00 Phillips under the XPS cover on the bottom. Also one of the #0 screws holding the battery down is #00. It is not necessary to remove the speakers but the wires are taped to the battery so pick and remove the tape.
scott Brawner - 回复 分享
Took me about 45 minutes.
Couple of complexities:
1. The speaker removal, it’s easier just to unscrew and pull out that way. Moreover, it’s easier the same way to replace, the problem is if you push in the speakers can remain wobbly unless you properly attach to the flexible plastic things.
2. When replacing the screws on the battery, do the little screw first. It shows it on the images, but doesn’t mention it, it’s a different sized screw (step 3).
3. Removing the screws on the back of the laptop is tough unless you have a good screw driver. In the end, I bought one from China from Aliexpress that was bang on what I needed.
Daniel Offer - 回复 分享
Does anyone have a source for a replacement battery? I checked Amazon but reviews were sketchy at best.
Andrew Chervenak - 回复 分享
I was concerned about the Amazon reviews as well. I ordered my battery directly from Dell for $85.
Samuel Adams - 回复 分享
Great guide! Came in real handy when I needed to replace a swollen battery.
Although the speaker removal part can be skipped completely.
Just remove the 4 Philip battery screws and peel off the black tapes securing the red/white speaker wires would be sufficient to allow the battery to slide right off.
Michael Wu - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 70
总计 21,154
