将电池电缆连接器拉向电池以将其与插座断开。
如果连接器很顽固,请在一侧轻轻推一下,然后在另一侧推,让它从插座中“走”出来。
如果你无法将连接器从插座中取出,请使用撬棒尖轻轻推动连接器凹口,将连接器滑出。
打开显示屏并按住电源按钮五秒钟以耗尽系统中的所有剩余电量。
插入更换电池,然后也插入电源适配器。 如果笔记本电脑既不充电也不开机,拔掉电池和充电器,然后取出并重新安装纽扣电池(CMOS、RTC;请参阅Dell’s guide)。
按照相反的步骤来重新组装你的设备。
按照相反的步骤来重新组装你的设备。
254等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
76条评论
Put compatible batteries under parts.
I followed the instruction carefully and it was quite helpful. However, now that I am done with the battery replacement, the speaker no longer works, and it seems that there is a hardware issue. Any thoughts on this?
@Sara - Looking on another ifixit procedure, I found that the speaker wires are taped to the battery, so I suspect that the speaker was not properly plugged in after reassemble, or that something happened to the wires during battery removal. Hopefully the wires weren’t cut or stretched.
Here is what the XPS 13 teardown procedure had to say:
“….After that, it still isn't a perfectly clean getaway—the speaker wires are strategically taped to the battery in a half dozen spots, which we'll have to liberate to free the battery. (Admittedly, it could have been a lot worse.)
These same wires are trapped under the battery screws—so speaker replacement means battery removal. It looks like the XPS has some layering issues.”
ref: Dell XPS 13 Teardown
I hope this helps.
